hiFace Hi-End S/PDIF Output Interface (Seite 1) - Wiedergabe und HiFi - AudioHQ
AudioHQ » Wiedergabe und HiFi » hiFace Hi-End S/PDIF Output Interface
Thema: hiFace Hi-End S/PDIF Output Interface
Nicht gerade billig, aber hilft die Tacktrate bei USB Ausgängen wesentlich zu erhöhen  :)
Für Windows und Mac Computer geeignet
http://www.m2tech.biz/products.html
Highest quality digital audio up to 192kHz/24bit
S/PDIF audio format available from your PC or MAC
Very low jitter oscillators and proprietary drivers
Compact size (2x2.2x10.2cm) with hi-end performances
hiFace USB interface has been conceived to obtain the highest quality digital audio signal using a PC or MAC. hiFace input format is a data stream signal with sampling frequency/resolution up to 192kHz/24bits, available from a PC or MAC USB port. A very high quality S/PDIF stereo audio output signal is available from hiFace for your Hi-Fi system DAC (Digital to Analog Converter). HiFace looks like a small USB pendrive, featuring a very compact size. Internal very low jitter oscillators and proprietary drivers allow for playing 192kHz/24bits audio files that feature the best signal quality.
Entdeckt in
http://www.macrewind.de/index.html?id=236
Fritz - KH: AKG K812, K712, Q701, K701, K501, K550, K271 MKII, Denon AH-D7000; Amps: "Green" SOLO, WNA MK II mod.
CD/SACD Player: Marantz SA7001 KI, Philips CD650 mod. / Phono: Revox B790 + Goldring G1042 MM
PhonoPre: Graham Slee "Green" Reflex; Verkauft: Sennheiser HD600, Stax SR044 / War zu Gast: Beyer T90, AKG K702, K1000
